xstatic
Posted: Thu Dec 22, 2011 8:32 pm Post subject: Samsung HP-S4233 video problem |
I have a Samsung HP-S4233 42 inch plasma tv and it displays solid fine bright multicolored colored lines throughout the screen. There are no free spaces anywhere. The tv images appears very faintly behind this image. All Inputs display the lines whether there is no signal or not. As soon as the tv is turned on the lines appear.
II heard a do it yourself solution was to replace a group of capacitors but the ones suggested look fine. Any suggestions. even knowing what board to replace would still be cheaper than a technician coming over.
The first imige is when you turn it on with no input.
The second image is the menu image, same as when you play a dvd or other input the image is the same
I even heated the various pc boards to see if the capacitors would fail and make it worse but no difference.
Any suggestions?[img][/img] |
