maloy2
Posted: Sun Aug 22, 2010 1:09 pm Post subject: Samsung Hp-s4253x/xaa restarts with remote use |
Hi, I have A Samsung Plasma Hp-s4253x/xaa. The TV works fine if I use the
buttons on the side, but when I use the remote (any button) the tv will restart. It dose this with the remote that came with the tv and the remote that works through the cable box. I think I need to replace ether the main board or the power supply. Can anyone tell witch board would cause this problem? Thanks |
Posted: Sun Aug 22, 2010 4:42 pm Post subject: |
Unless the power supply has a dedicated supply just for remote operations, I think you can rule that out.  |
maloy2
Posted: Sun Aug 22, 2010 7:40 pm Post subject: |
How can I tell if the power supply has a dedicated supply just for the remote operation |
Posted: Sun Aug 22, 2010 7:53 pm Post subject: |
They will use the stand-by 5 volt source for the "brains" (microprocessor) and the remote, so if its up to snuff, you should be good there. |
maloy2
Posted: Mon Aug 23, 2010 3:38 am Post subject: |
I'll order a main board and get back to you later to let you know how things worked out. Thanks |
maloy2
Posted: Mon Aug 30, 2010 1:09 pm Post subject: |
I put a new main board in today, $204.00
It fixed the problem.
Thanks for the help |
Posted: Mon Aug 30, 2010 1:46 pm Post subject: |
thanks for posting back. |
