Samsung HP-T4254 HDMI port problem
ash303
PostPosted: Fri Dec 10, 2010 5:54 pm    Post subject: Samsung HP-T4254 HDMI port problem Reply with quote
I have a 42inch Samsung flat screen. Yesterday my computer was connected to the tv via hdmi cable and there was a power surge. My computer won't boot anymore, and anything I connect to any of the hdmi ports on the tv won't display an image. The components connections still work, but the hdmi is acting wierd. If I have anynet turned on, and I plug in my bluray player, it will jump to HMDI input 1, even if it's plugged into either of the other 2 ports. No image shows up. I change the source to the hdmi port the bluray is plugged into, and still nothing. If I do plug the hdmi cable into port 1, it'll still jump to that port when I turn on the bluray player, but show no image and if I cycle through the sources, it will say there is nothing connected. By the way, the computer was plugged into hdmi port 1 when there was a surge. are the hdmi ports shot? can they be replaced? Is this something I can fix? Thanks in advance.
-ash
