samsung hp-t4254 plasma clicking !!Repaired!!
ntehicks
PostPosted: Fri Apr 15, 2011 2:44 pm    Post subject: samsung hp-t4254 plasma clicking !!Repaired!! Reply with quote
I have a Samsung HP-T4254 that will turn on for about 2 min. and then turns off. when I try to turn the tv back on it clicks and won't turn back on. thanks for the help..
Update... I looked around on line and found a kit that had a few FET's that you would replace to fix this issue. I tested these parts and found that they tested good. Both parts had bad ring cracks on MOSFETs QX801 & QX802. I re soldered and tested. TV has been working flawless for the past 3 days. Thanks
Jerk_206
PostPosted: Tue Jan 27, 2015 12:33 pm    Post subject: Thanks Reply with quote
I registered for this forum just to tell you thanks for the fets info. Worked like a charm.
