im1dermike
Posted: Mon Sep 14, 2009 1:12 pm Post subject: Samsung LCD "blinking" HDTV-LN-T4061F |
I've had a 40 inch Samsung 1080p LCD HDTV for a few years. On two separate occasions within the past week, it has had a weird "blinking" phenomenon. To describe the situation in more detail, I'll be watching the TV and after a while, out of no where, the screen will start "blinking". The correct picture and blackness will take turns flashing back and forth multiple times a second. It's definitely the TV and not the cable signal because I've tried different inputs.
I believe, in both instances, it was triggered by a channel change. To try and remedy the situation, I just try turning the TV off and on again, and changing the channel. Finally, it will go back to normal.
Any ideas? |
Posted: Mon Sep 14, 2009 1:46 pm Post subject: |
model |
im1dermike
Posted: Mon Sep 14, 2009 1:47 pm Post subject: |
Samsung-40" 1080p Flat-Panel LCD HDTV-LN-T4061F |
Posted: Mon Sep 14, 2009 2:32 pm Post subject: |
I'd check the caps in the power supply. they're known for failing. |
im1dermike
Posted: Mon Sep 14, 2009 2:33 pm Post subject: |
Thanks for your reply kuhurdler. Can you explain in a little more detail what that would entail for a novice please? |
im1dermike
Posted: Mon Sep 21, 2009 9:24 am Post subject: |
I'm fairly handy and there was no way I was going to try that task myself and ruin my TV. A Samsung repair shop diagnosed a failed inverter card. |
Posted: Mon Sep 21, 2009 10:27 am Post subject: |
good to know. How much did they charge? |
