_Ming Guest
Posted: Sun Sep 20, 2009 1:05 pm Post subject: Samsung LCD TV model LNT4065FX/XAA fixed |
Samsung LCD TV model LNT4065FX/XAA fixed, It has vertical thin line on all over the entire screen. Later I will post this screen picture little bit later.
Tjhis screen picture will tell you it is the main board problem, but it is not. The real problem is the power supply board the 10V 1000uf capacitors dry out so that no sufficient supply to the main board and make this screen picture and problem.
The link is """""http://www.mediafire.com/?sharekey=13d24b809029382fd2db6fb9a8902bda"""" the files name is """"" HPIM1372 """"""
another """"" HPIM1380 """""" picture is the picture of this power supply at the top right corner, there is few 1000uf 10V caps all of them need change. |
