chacik82
Posted: Wed Nov 04, 2015 1:03 am Post subject: Samsung LE32551A6W - No image, sound OK |
Hi
I have old Samsung TV LE32551A6W and it had worked for me 5 years with no problems. Until recently, few days ago during normal use, it switched the video off while sound was still on. I switched it off and back on, and image appeared for 2 seconds and went black again. Sound is still on, signal comes in with no problem. I cannot see menu, or anything no matter what is the source.
After reading few forums I checked the screen at different angles but there is nothing showing, not even a faint image.
Can you tell me what could be a possible reason for this fault and solution to it, and if it is worth fixing, or should I go for new one?
Thanks for all help.
Martin |
