samsung LE40M87BDX/XEH big problem
olddog45
PostPosted: Tue Jan 21, 2014 3:48 am    Post subject: samsung LE40M87BDX/XEH big problem Reply with quote
hello
i have a Samsung LE40M87BDX/XEH and recently appears some problems with the picture,the problem is that the faces an especially noses, forehead ,cheeks its very white and shiny or turned to pink, i forced to adjust brightness and color very low and is was little better, ,but now its very dark. anyway that was the small problem Crying or Very sad because yesterday i try to "play" with the adjustments in service menu for a try to fix it,but i don't remember what i change,of course i thought if you push the factory reset even if you do wrong will be ok,but i thought WRONG, now i have totally distorted picture and after 5 resets nothing happened,did someone have the full settings of service menu?or some other solution? thanks be forehead and sorry about my bad English
greetings from bankrupted Greece Smile)
PostPosted: Tue Jan 21, 2014 6:34 am    Post subject: Reply with quote
ďA person who represents himself has a fool for a client." Abraham Lincoln
Sorry, I didn't find anything in your Owner manual's Troubleshooting section about what to do after having "played" with adjustments in the SERVICE menu.
Customer Menu is for Customer - Service menu is for servicer.
I will now stop beating the dead horse. (Sorry horse.)
Bring to a TV Repair Shop - confess your sin - pray they can restore.
