roberted1982
Posted: Tue Dec 13, 2016 6:28 pm Post subject: Samsung LED UN50H6350AF - no video |
I have a 50 in LED 1080 p Smart tv. I was watching tv and the picture just went black but the sound stayed.
I read where it was the power board.
Opened the TV up and got the power board out. There was a high temp burned spot so I replaced it.
Same thing.
So then I was told about the T-Con board might be out. So I replaced this board as well with nothing new going on. The back lighting does work. I can hear menu options when I trying to move around with the remote. But I have ZERO picture.
I'm hoping its not the main board after all this.
Any help would be awesome |
Posted: Tue Dec 13, 2016 7:16 pm Post subject: |
Do ALL the LEDs light (and stay lit) when plug CNM803 is disconnected? |
roberted1982
Posted: Tue Dec 13, 2016 7:55 pm Post subject: |
JTS1957 wrote: | Do ALL the LEDs light (and stay lit) when plug CNM803 is disconnected? |
Which plug are you referreing to? I'm not 100% sure |
Posted: Tue Dec 13, 2016 8:50 pm Post subject: |
Lower left |
roberted1982
Posted: Tue Dec 13, 2016 9:25 pm Post subject: |
Ok just took the back off plugged in the TV. It's NOT on but plugged in. When I removed the plug you said to remove the back lighting lit up. |
Posted: Tue Dec 13, 2016 10:20 pm Post subject: |
roberted1982 wrote: | the picture just went black but the sound stayed. | (backlights are lit during the above)
roberted1982 wrote: | I can hear menu options when I trying to move around with the remote. | (backlights are lit during the above)
roberted1982 wrote: | The back lighting does work. |
IF you can't see ANY trace of video (Try using a flashlight angled very close to the screen) and you HAVE audio AND you can't see any trace of menu, since you've already replaced the tcon (this presumes you received a 'good' tcon and that B-Plus IS reaching the tcon board), then this only leaves the Main board and the panel itself. |
roberted1982
Posted: Tue Dec 13, 2016 10:27 pm Post subject: |
JTS1957 wrote: | roberted1982 wrote: | the picture just went black but the sound stayed. | (backlights are lit during the above)
Ok So if I can see any picture at all with a flash light means my panel is bad?
If I can't see any picture with the flash light means my main board is bad? |
Posted: Tue Dec 13, 2016 10:40 pm Post subject: |
Which board(s) did you replace? There are more than one (I presumed the ONLY one shown for YOUR power board for example, but tcon & mains have multiple possibilities.)
Power and tcon especially. F200 on tcon should be a good place to measure your B-Plus.
IF you CAN see video with flashlight, especially IF you CAN also see OSD, that would prove the panel and the tcon are GOOD. |
roberted1982
Posted: Wed Dec 14, 2016 12:19 am Post subject: |
Not sure this B-Plus.
IF you CAN see video with flashlight, especially IF you CAN also see OSD, that would prove the panel and the tcon are GOOD.[/quote]
I am using a Streamlite police style light on the tv. I see nothing. But I am also not sure I am on a source that is working on the tv. I have my computer hooked up to it and doing a extend desktop setup now. My desktop is red so you would think I could see it. So as of now I see nothing. |
Posted: Wed Dec 14, 2016 12:34 am Post subject: |
With a DVM set for DCV, measure for DC Voltage between chassis ground and both sides of F200 OR F200(bottom left).
