Samsung LN-T4671F Control Problems
spags13
PostPosted: Sun Sep 04, 2011 2:38 pm    Post subject: Samsung LN-T4671F Control Problems Reply with quote
RE: Samsung LN-T4671F......TV Control Problems.............Have replaced Power Supply Board once, for the flickering power issues going back a couple years. Second time it happened, replaced bad capacitors with the higher voltage rating.
When installed board with new good higher voltage caps, the audio was stuck between low and medium. Remote control or side of TV controls did not work at all.
Stayed with that for a while, then tried replacing caps with original voltage and as soon as I plugged in TV, volume on screen starting moving to lowest setting by itself.
Now I have no sound/audio whatsoever.
Great Picture with no sound.
Any help or advice would be appreciated.
PostPosted: Sun Sep 04, 2011 4:46 pm    Post subject: Reply with quote
is the volume panel button open or closed?
spags13
PostPosted: Mon Sep 05, 2011 5:13 am    Post subject: Reply with quote
Don't know exactly what you mean by"volume panel".
There is no panel on TV for controls.
Just the signs on front right side for Power, Source, + VOL - , <CH> ,
I think they used to light up, but you just pressed on them to work.
I'm thinking that maybe changing the bad caps with higher voltage good caps, 2 of them from 10v to 16v might have affected whatever powers
the control panel and /or ir sensor for remote control.
But I'm far from an expert, so I'm really confused as to what might have caused this to happen, and where on power supply board or other board I could check for problem, or specific location that controls these functions.
I do have an extra power supply board that I can mess around with, with both 10 and 16v extra caps for replacement.
Thanks for your quick response.
PostPosted: Mon Sep 05, 2011 6:10 am    Post subject: Reply with quote
yes, those are the buttons I was referring to. I suspect that the buttons are jammed or failing in general.
I doubt changing it from 10v to 16v would cause that, unless you accidentally bridged a circuit with a solder splash. I think it's more likely that some other component is causing that behavior.
PostPosted: Mon Sep 05, 2011 12:16 pm    Post subject: Reply with quote
Or plugging a connector into the wrong spot ... or bending one or more pins of a connector as its being plugged in, etc.
spags13
PostPosted: Wed Sep 14, 2011 9:43 pm    Post subject: Reply with quote
Well ended up getting a local tv repair guy, who replaced main board, and got my ir sensor and remote working again.
Controls on side of TV still not working. But that was another problem.
