Samsung LN40A450C1DXZA Power supply replacement
yufrettin
PostPosted: Sun Nov 13, 2011 1:18 pm    Post subject: Samsung LN40A450C1DXZA Power supply replacement Reply with quote
I have a 42" Samsung LCD tv which had no power. Im aware of the capacitor problems with samsung and called the manufacturer. Luckily they sent a repair tech, even though this tv was no longer under warranty, who replaced the capacitors which were bad. Samsung covered this replacement and I was not charged.
However my tv was still not getting any power and I was told that the power supply also needed to be replaced. I was quoted $150 to do the job.
I found the power supply online (shopjimmy.com) for about $60 - half of the part price I was quoted. They quoted me a labor charge of $30 and I can order the part and bring it in to them to replace. However I'm wondering if it's difficult to replace the part myself.
Thoughts? Ideas?
PostPosted: Mon Nov 14, 2011 8:39 am    Post subject: Reply with quote
$30 is a steal for labor.
Usually there is a minimum ~$75 just to deal with you.
yufrettin
PostPosted: Mon Nov 14, 2011 9:53 am    Post subject: Reply with quote
They already received payment for labor and parts and house visit from Samsung for the capacitors replacement... which is likely why they are charging me $30 instead of more, I would guess that they've already made a profit at this point.
There isn't alot of information online on how to replace a power supply but from what I've seen there's no soldering involved and it's pretty clear cut. If it's something I could do myself it would really help me out.
Thanks!
PostPosted: Mon Nov 14, 2011 12:17 pm    Post subject: Reply with quote
Plug 'n Play.
Remove plugs, marking if you must;
remove fasteners;
swap boards;
install fasteners & plugs;
Done.
yufrettin
PostPosted: Mon Nov 14, 2011 1:02 pm    Post subject: Reply with quote
Plug n play is something I can do. Thank you JTS!
PostPosted: Mon Nov 14, 2011 5:50 pm    Post subject: Reply with quote
You forgot dis-assembly and reassembly.
