Samsung LN46C630K1F remote sensor eye in TV got wet?
jkey59
PostPosted: Sun Oct 21, 2012 10:58 am    Post subject: Samsung LN46C630K1F remote sensor eye in TV got wet? Reply with quote
Samsung model# LN46C630K1F(277680)
Problem: TV got wet and since the remote will not work with the TV. I have to manually work it using the buttons on front of TV.
I've checked the remote and that is ok.
Removed the front frame of TV and found the sensor eye is under a circuit board and hesitant about removing that.
Is there a way to check the sensor eye with the circuit brd. on it or does that need removed? Can't afford a repairman at this time.
In advance, thank you..
