CSTJAMES
Posted: Tue Feb 28, 2012 6:32 pm Post subject: Samsung LNT5271f display problem |
I have a samsung LNT5271fx/xaa that has two issues. The first was the well known on off nonsense. I did the repairs to the PCB caps and that worked out well. The other issue is that the right side of the screen has multiple images that flicker. At first it would clear after a few minutes, but now it's there to stay. After some research on this $2,000 anchor, I followed some advice and changed the T-CON board. Nope, didn't change a thing. So, before I take this piece of junk out and shoot it,( I used to throw a brick at the older picture tubes, but LCDs just don't have the same kick ) is there any other possibilities on this issue? Sure, there's about a million, but if someone has had this issue and found a fix I would love to have you share it with the forum. Thanks CSJ |
