Samsung SA350 Check Signal Cable fix
PostPosted: Sun Aug 05, 2012 2:50 pm    Post subject: Samsung SA350 Check Signal Cable fix Reply with quote
Had this (20"?) LED (LCD) monitor that would not take a VGA input, It kept flashing "Check Cable Signal - Digital". Once I connected a DVI cable with a functional DVI source, I could go into the menu and change the settings to allow VGA.
This is not an equipment or circuit failure, it's a poor design. Hopefully this will prevent someone else from pitching their fully-working monitor.
PostPosted: Mon Aug 06, 2012 2:45 am    Post subject: Reply with quote
Owner's manual http://downloadcenter.samsung.com/content/UM/201101/20110121080524825/BN59-01128A-00Eng.pdf
Pages 5-1 Monitor Self-Diagnosis & 5-2 Before Requesting Service
You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the <Check Signal Cable message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is the <Check Signal Cable message displayed on the
screen?
(Connected using the D-sub cable)
Check the cable connecting the PC and the product.
(Connected using the DVI cable)
If the message appears on the screen even if the cable is
properly connected, recheck the input signal by pressing the [
] button of the product.
PostPosted: Mon Aug 06, 2012 11:19 am    Post subject: Reply with quote
It would indeed let me enter the on screen menu, however all the menu options were greyed out (unavailable) until I plugged in a DVI cable with a functional source.
