bdtprez
Posted: Thu Oct 29, 2015 11:28 am Post subject: Samsung SP-P4231 vertical line f-buffer? |
I have a Samsung SP-P4231 plasma with a single vertical line (only about 1 pixel wide) running from top to bottom directly in the center of the screen. The line shows on all inputs and even on the on screen menu. It is for the most part, a black line as it is not visible on black areas of the screen but it appears white when it intersects the on screen menu's blue bars. I have removed and cleaned the contacts of the F-Buffer with no change. Before I buy a replacement f-buffer, can anyone with experience tell me if this will likely solve my problem? Thanks! |
