samsung t240hd
sevichenko
PostPosted: Thu Jul 16, 2009 9:54 am    Post subject: samsung t240hd Reply with quote
hi friends, i'm a newbee from spain, first of all, please forgive my poor english Sad
i have some problems with my monitor/tv
when i push source button (from pc to hdmi, or from components to ext, or...) needs about 10 to 15 seconds to change, i mean that if i'm in hdmi and i want to put pc i have to wait this time.
and when i press power button to power on the tv, i have to wait from 10 to 15 seconds.
do you know if this is normal?
thanks friends!
PostPosted: Thu Jul 16, 2009 10:20 am    Post subject: Reply with quote
Samsung stateside has no information available on their website for your set. However, Since you are in Spain, you are on the PAL system and your set is most likely a multinational TV set. That being said, when you change inputs your set has to determine which system is currently being input and then set itself up for that system. You may possibly help speed your system up by taking it off of AUTO and setting it to your system which is PAL. Since I do not have the Literature Handy I would suggest you go on the internet and download the operaters manual or if you already have it it will show you how to put the set in a manual state.
This procedure is fairly simple and may or may not speed your set up.
Hope this helps.
sevichenko
PostPosted: Thu Jul 16, 2009 11:06 am    Post subject: Reply with quote
hi friend, thanks for answer.
but i don't know how to put in manual these things Sad
PostPosted: Thu Jul 16, 2009 11:59 am    Post subject: Reply with quote
The Procedure will be in your owners manual
sevichenko
PostPosted: Thu Jul 16, 2009 12:03 pm    Post subject: Reply with quote
and what about the name of the option? how i have to search it?
