Samsung Guest
Posted: Thu Jul 19, 2007 5:53 am Post subject: Samsung TV Service Menu Codes - PLASMA / LCD / CRT / RPTV |
# Turn on the TV on and select the input that you want to adjust.
# Turn the display off.
# In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}. |
Samsung Guest
Posted: Thu Jul 19, 2007 5:54 am Post subject: Service Menu Code |
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
* Press the {POWER} button to exit the Service Menu. |
Samsung Guest
Posted: Thu Jul 19, 2007 5:55 am Post subject: Service Menu Code |
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
* Use the {CH+} {CH -} buttons to select items.
* Use the {VOL+} {VOL -} buttons to adjust.
Sansung Guest
Posted: Thu Jul 19, 2007 5:56 am Post subject: Service Menu Code |
{P.STD} {HELP} {SLEEP} {POWER} buttons on the remote.
or
{P.STD} {MENU} {SLEEP} {POWER} buttons on the remote.
Samsung Guest
Posted: Sat Jul 21, 2007 2:06 am Post subject: Service Menu Key Sequence |
{SLEEP} {P.STD} {MUTE} {POWER} on the remote.
