Samsung TX-R2779H Picture/Brightness Issues
runnonempt
PostPosted: Mon Mar 16, 2009 9:56 am    Post subject: Samsung TX-R2779H Picture/Brightness Issues Reply with quote
Good morning. This TV acts like a 'dimmer switch' at times. The picture fades darker, then it will come back normal. Then it will go brighter. It does it on Video inputs and RF and is not constant. I do not use the HDMI or components. Any idea of what I could do to repair?
Model - TX-R2779H
SVC Model - TXR2779HKX/XAA
Type - CR29Z30
Thanks.
PostPosted: Mon Mar 16, 2009 10:36 am    Post subject: Reply with quote
sounds like the knob that adjusts the screen voltage is failing. it is probably attached to the flyback.
PostPosted: Mon Mar 16, 2009 2:17 pm    Post subject: Reply with quote
CRT Filaments?
curt wolfe
PostPosted: Mon Mar 16, 2009 3:47 pm    Post subject: Reply with quote
check for poor solder connections on high voltage transformer, also on crt socket.
