Samsung txe1970 flyback replacement
tonyynguyen
PostPosted: Wed Oct 08, 2008 8:32 pm    Post subject: Samsung txe1970 flyback replacement Reply with quote
Hi, I have a Samsung TXE1970 analog tv with sparks coming out of the flyback.
I was wondering when I replace the flyback, does it has to be the exact model number?
The flyback model number is FSV-20A001. I was wondering if I could replace this flyback with a FSV-20B001.
The horizontal output transistor was also shorted, and i plan to replace that also. D5070
thanks
PostPosted: Thu Oct 09, 2008 7:09 pm    Post subject: Reply with quote
Samsung does not list any information on this model other than an owners manual. Do not guess as to substitutions. You will do much more harm than good. However, if you input the number FSV20A001 (without the dash) on the MCM website there is a substitution available for $25.51
As to the horizontal output, is the number you gave printed on the transistor or a schematic location number printed on the circuit board.
If it is printed on the part and is accurate I did not find any source, even Samsung, for this part. (If it is printed on the part you have to add a 2S prefix on the printed number ex: D5070 = 2SD5070) I also looked at the substitution book for transistors and that number is way to high.
After you locate a transistor do not forget to resolder the driver transformer. This is what usually causes the cascade failure.
