Davyn
Joined: 14 Oct 2015 Posts: 3 Location: Paramaribo, Suriname
Posted: Wed Oct 14, 2015 11:22 am Post subject: Samsung UN46ES8000F - vertical lines on left side of screen |
Hi,
My Samsung tv has mostly thick black lines on the left side of the screen with also a lot of thin colored lines disappearing to the right side of the screen, where as the right side of the screen is almost completely 'okay'..
Any suggestions on what the problem could be or how to track down what could be the problem?
Product info: Samsung SMART 3D
model: UN46ES8000F
Thanks in regard.. |
Posted: Wed Oct 14, 2015 11:31 am Post subject: |
It might help if you could provide a picture. I recommend uploading to imgur.com and provide us a link to the image.
Just based on your description, I suggest opening it up and reseating the LVDS cable. |
Davyn
Posted: Thu Oct 15, 2015 8:17 am Post subject: |
kuhurdler wrote: | It might help if you could provide a picture. I recommend uploading to imgur.com and provide us a link to the image.
Thanks kuhurdler, I will try that.
Here's the picture I took. Hope it's clear enough.. http://imgur.com/PpqdKZg |
Posted: Thu Oct 15, 2015 8:50 am Post subject: |
try reseating your ribbon cables first. Then check the tab bonds on the tops of the panel itself. Don't remove the tab bonds, but poke around on them and see if they impact the image. |
Posted: Thu Oct 15, 2015 11:29 am Post subject: |
Is OSD or Menus being affected? Actually, that is a OSD - nevermind. |
Davyn
Posted: Fri Oct 16, 2015 11:01 am Post subject: |
kuhurdler wrote: | try reseating your ribbon cables first. Then check the tab bonds on the tops of the panel itself. Don't remove the tab bonds, but poke around on them and see if they impact the image. |
So I have reseated the ribbon cables 1 and 2 as shown in the picture, but I got confused with the tab bonds.. Are those behind the frame or are they cables number 3 in my attached picture? Ps. I have already been poking those, but no avail.. http://imgur.com/XQ6f09h
http://imgur.com/ykorep6 |
Posted: Mon Oct 19, 2015 12:29 pm Post subject: |
#3 is what I was speaking of.
Tab bonds will be under the metal shield around the outer edges. It's somewhat easy to damage the panel if you aren't gentle though. |
