Samsung UN65H7150 - only backlight, no picture
ghiros
PostPosted: Sun Sep 09, 2018 2:23 pm    Post subject: Samsung UN65H7150 - only backlight, no picture Reply with quote
Hello,
I'm trying to get some informed guesses about what could be wrong with my TV. When I plug it in, the backlight comes on immediately, but there is no picture, no menu. It doesn't respond to remote input or using the physical button (i.e. I cannot even turn it off without unplugging it).
Can't tell whether there is sound, because I can't be sure which input it might be set to.
I'd rather not replace components willy nilly, because they seem to be quite pricey for this model.
Thank you for any input you might have!
PostPosted: Mon Sep 10, 2018 8:37 am    Post subject: Reply with quote
Presuming all power supply CNM803 voltages are present, Main Board is likely.
ghiros
PostPosted: Tue Sep 11, 2018 9:10 am    Post subject: Reply with quote
Thank you, I will check this out and report back.
ghiros
PostPosted: Tue Oct 02, 2018 11:36 am    Post subject: Reply with quote
After checking voltages and eventually replacing the main board, the TV is back in business.
Thanks to jts1957!!
