Samsung XL2370 - bad HDMI connection
sn0wer
PostPosted: Sat Oct 28, 2017 7:33 am    Post subject: Samsung XL2370 - bad HDMI connection Reply with quote
Hello everyone,
Noticed the HDMI port is loose, I soldered the connector's structure to the PCB (noticed an attachment point breaked). The screen still doesn't detect HDMI connection from time to time AND when I try to move the cable around, the screen switches off (as if there's a short and the screen goes in protection mode).
Should I go ahead and replace the HDMI port ? Does this problem ring a bell to anyone ?
Thank you.
Note : here is an image of the HDMI port :
https://imgur.com/gallery/pqD03
PostPosted: Mon Oct 30, 2017 7:05 am    Post subject: Reply with quote
I'd guess that the physical HDMI port is still broken or loose based on your description. perhaps those surface mount pins that carry the HDMI signal.
