sanyo d525380 snow
deb963
PostPosted: Tue Oct 21, 2008 7:00 pm    Post subject: sanyo d525380 snow Reply with quote
I have a sanyo model d525380 serial n v9060340721305. Im having problems with the tv. When i turn on the tv the tv turns too snow then about 10 minutes you can see the tv then again back in 10 minutes turns to snow again. I have to keep playing the on and off switch so it can give me that picture that is showing then again it turns to snow. Is this tv repairable or should i get another tv?
PostPosted: Tue Oct 21, 2008 9:38 pm    Post subject: Reply with quote
It is repairable.
I would suspect the tuner is faulty. Check that the tuner is getting 24V. If so, replace the tuner.
deb963
PostPosted: Wed Oct 22, 2008 1:53 am    Post subject: tv repair Reply with quote
Where is the tuner located? How would i check if its getting 24v .What tool do i need?
