SANYO DP50749 artifact issue
jbm1976
PostPosted: Mon Aug 23, 2010 6:49 pm    Post subject: SANYO DP50749 artifact issue Reply with quote
SANYO DP50749 artifact issue. most parts inside are made by LG. I took a video and a photo. Its almost like things are bleeding over to the right hand side of things. also they are in lines going up and down. like when i have no input hooked up it says no input found and it flashes around the screen and you can see a trail off to the right hand side of it. also when you watching a movie you see them off the right hand side of things. I already looked over the power boards and all caps and solder joints look good. I am wondering if its the logic board or what. i also hear a sound coming from the ysus. like a high voltage sound but not sure if thats normal for that part or not. its not that notisable unless your or lissening for it.
http://www.youtube.com/watch?v=9xW0L0Tu0y0
I hope some of you have an idea what would make this happen.
