Sanyo dp50842 No Picture
bmurray1981
PostPosted: Thu Nov 13, 2014 1:43 pm    Post subject: Sanyo dp50842 No Picture Reply with quote
There was a spider on the screen. My father in law killed it with his hat and i knocked the picture out. Has sound but you can see a small white spot on top of screen where he hit it. All help appreciated
PostPosted: Thu Nov 13, 2014 5:24 pm    Post subject: Reply with quote
PROTECTING THE LCD SCREEN
CAUTION: The screen can be damaged if it is not maintained properly.
Do not use hard objects such as hard cloth or paper to clean the screen.
Do not use excessive pressure when cleaning the screen; excessive pressure (INCLUDING killing spiders with hard hats) can cause permanent discoloration and dark spots.
NEVER spray liquids on the screen.
PostPosted: Fri Nov 14, 2014 12:14 pm    Post subject: Reply with quote
Yep I've broken a couple myself trying to reassemble them. Always a bad day, and it's shockingly easy to break them.
only way to fix it is a new panel... which you wont want to pay for. Only thing you can do is take it apart and sell the boards on Ebay.
