Sanyo Dp50843-00 - Power On Issue
lordsecs
PostPosted: Mon Jan 25, 2016 2:46 pm    Post subject: Sanyo Dp50843-00 - Power On Issue Reply with quote
above Model when plugged in no indicator lights (Standby or Power) Set appears to be dead. All voltages on PS are correct. If I press the power button once and walk away the set will come on in 5 to 10 min and work normally. What am I missing?
PostPosted: Mon Feb 01, 2016 9:58 am    Post subject: Reply with quote
This is odd. if you're sure your power supply is providing clean power, I'd start checking voltages on the mainboard.
lordsecs
PostPosted: Mon Feb 01, 2016 10:00 am    Post subject: Reply with quote
I ordered the EPROM will post results
lordsecs
PostPosted: Mon Feb 01, 2016 2:25 pm    Post subject: Reply with quote
All Fixed $15.00 EPROM from Shop Jimmy.
PostPosted: Mon Feb 01, 2016 3:29 pm    Post subject: Reply with quote
Well done. Thanks for posting back
