sanyo ds24425 dead
mksteller
PostPosted: Fri Oct 31, 2008 3:58 pm    Post subject: sanyo ds24425 dead Reply with quote
I got this set the other day the problem at the time was it would shut off within three seconds of start up. I took the cover off and did a visual inspection of the board saw nothing abnormal. plugged it in and turn it on made the normal clicking sound then shut down I did this a few times then something strange happened. it started to spark I believe the spark came from ch609 but not completly sure because it was very fast. after the spark the fuse blew I replaced the fuse but now it does nothing. can anybody give me some ideas on what to check for ? this set is only two years old and I would like to see it work again. I've been looking online for info but can't seem to find much on this model. also since fixing my last set I found out about the solder sucker, I am know the proud oner of one. can't wait to use it
