sanyo model ds31590   Goto page 1, 2  Next
1968RT
PostPosted: Wed Dec 29, 2010 4:54 pm    Post subject: sanyo model ds31590 Reply with quote
When I got the tv the power switch and volume down switch were missing.
I removed the volume up switch and put it in the power switch opening. The tv turned on in the video input mode. Hooked up to the input and got a picture. Using the switch the tv powers up, but not down. The menu switch does nothing. VIDEO shows on the screen. Don't have the remote, but tried programming a universal. No code worked. Do the 2 missing switches have to be on the PCB, or are there other larger problems causing these conditions?
PostPosted: Wed Dec 29, 2010 5:37 pm    Post subject: Reply with quote
Set will work with ALL switches off the board. A momentary jumper wire across switch's contact pads or a command from a remote should operate each function. I suspect that either a switch is/was intermittently shorted and/or you may have other problem(s) with set. You can test each switch with an ohmmeter - should be less than 1 ohm when pressed and, in theory, infinite when not pressed (out of circuit - if in circuit, the reading when not pressed depends on what else is in the circuit).
Let's see if set can go to service mode:
Unplug TV - While pressing "menu" (do NOT press any other keys - you don't want to change anything else) plug set into outlet - release "menu" - if working correctly a string of information will be seen on the screen - Press "menu" again to remove.
1968RT
PostPosted: Wed Dec 29, 2010 6:30 pm    Post subject: Reply with quote
Are you saying when the tv is plugged in with ONLY the menu button being pushed it will power up? If so no dice. I Then tried plugging it in while holding both the menu and power buttons - it turned on, but no service codes. The guy I got it from said there was a problem with the power switch. He was the one who removed the switches. He repairs MRI machines for a living, so he is no novice at electronics. I guess it's possible that the power switch was shorted then. He bought a new flat screen, and so didn't go any further with trying to repair this one
PostPosted: Wed Dec 29, 2010 7:10 pm    Post subject: Reply with quote
1) With the TV "on" and playing - Unplug the TV;
2) press and hold the "menu" button;
3) while still pressing and holding the "menu" button, Plug in the TV;
4) release the "menu" button.
If set displays SERVICE MENU press "menu" and release to see if it disappears as it should.
1968RT
PostPosted: Wed Dec 29, 2010 7:24 pm    Post subject: Reply with quote
Tried several times - no power up.
PostPosted: Wed Dec 29, 2010 7:33 pm    Post subject: Reply with quote
What do you mean set won't power up?
1968RT
PostPosted: Wed Dec 29, 2010 7:45 pm    Post subject: Reply with quote
I followed your steps exactly. When I plug the tv in while holding the menu button it does not come on. Also just to experiment I used a jumper wire in place of the volume up switch and got no sound or volume indicator on the screen ( I am assuming there would be some on screen indicator of volume level). I also plugged the set back in while holding no buttons - no power up unless I push the power switch.
1968RT
PostPosted: Wed Dec 29, 2010 7:47 pm    Post subject: Reply with quote
When I say power up I am reffering to a picture on screen.
PostPosted: Wed Dec 29, 2010 8:00 pm    Post subject: Reply with quote
Do you have a DVM (ohmmeter)?
1968RT
PostPosted: Wed Dec 29, 2010 8:07 pm    Post subject: Reply with quote
Yes
Goto page 1, 2  Next
Page 1 of 2
