Sanyo Guest
Posted: Thu Jul 19, 2007 5:59 am Post subject: Sanyo TV Service Menu Codes |
* Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit. |
Sonya Guest
Posted: Thu Jul 19, 2007 6:00 am Post subject: Service Menu Code |
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Sanyo Guest
Posted: Thu Jul 19, 2007 6:01 am Post subject: Service Menu Code |
PROJECTORS :
* Press and hold the {MENU} and {INPUT} buttons on the projector simultaneously for 5 seconds.
or
Press and hold the {MENU} button for 20 seconds.
* The "S" mark appears on the screen.
* While the "S" is being displayed, press and hold the {UP} and {DOWN} buttons on the projector
or
{SCREEN} button on the remote for more than 3 seconds.
* The Service Menu will be displayed.
* Adjust service data using the following control buttons:
{OK} ................ A group number increases.
{MENU} ............ A group number decreases.
{UP} ................ An item number increases.
{DOWN} .......... An item number decreases.
{RIGHT} .......... An adjustment value increases.
{LEFT} ............ An adjustment value decreases.
* To quit the service mode, press the "POWER ON/OFF" button only once on the projector or the remote control. |
Sanyo Guest
Posted: Thu Jul 19, 2007 6:03 am Post subject: Service Menu Code |
PROJECTORS :
* Factory Menu Access:
Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
* The Factory Menu will be displayed.
* Service Menu Access:
Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
* Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
* To exit, turn the Projector Off. |
Sanyo Guest
Posted: Sat Jul 21, 2007 2:05 am Post subject: Service Menu Key Sequence |
* Press & hold the {MENU} button on the Projector for about 10 seconds.
