Service Codes for Toshiba 20A23 Mono Television (2003)
Tregaskis
PostPosted: Sun Apr 17, 2011 3:43 pm    Post subject: Service Codes for Toshiba 20A23 Mono Television (2003) Reply with quote
Does anyone have the service codes for this tv? There is no sound at all.
I can access the service menu but do not have the values for the 29 options available. Can anyone help?
Greg
PostPosted: Mon Apr 18, 2011 11:57 am    Post subject: Reply with quote
Did you try all of these Service Codes
PostPosted: Mon Apr 18, 2011 1:28 pm    Post subject: Reply with quote
This (along with the proper test equipment) will tell you how to set most of the adjustments.
Now if you've already been diddling, we can't supply you with the "original" values - you should ALWAYS write them down BEFORE diddling occurs.
http://elektrotanya.com/toshiba_20a23.pdf/download.html
Tregaskis
PostPosted: Mon Apr 18, 2011 5:58 pm    Post subject: Thanks for the manual Reply with quote
I found the codes in the service manual...they were all exactly as the tv was set except for the T-Mono code...the tv was set to 25 and the book says the code should be 00. I set it to 00 but still no sound.
Any suggestions? BTW...I never changed the codes when I was diddling
the first time so they were all as I received the tv Smile
Greg
PostPosted: Mon Apr 18, 2011 6:30 pm    Post subject: Reply with quote
What is rest of history? How did you arrive at the conclusion that it must be an adjustment that's causing fault? Has audio output IC produced audio with test tone injection (pin 4 muted/unmuted)?
