garberfc
Posted: Thu Feb 26, 2009 7:10 pm Post subject: Service menu code for panasonic CT-32XF56 |
I've searched for but can't find the code for the model mentioned in the subject.
I found the thread for Panasonic, and specifically the section for CRTs. It doesn't work for my TV...
Any suggestions are very appreciated.
F |
Posted: Fri Feb 27, 2009 12:17 pm Post subject: |
My suggestion is:
Since you have not given a symptomatic condition, I can only guess as to the reason for wanting to access the service menu.
That being said please note: Service menu's are not for repairing a tv set. They are for alignment and adjustments only.
You have a DX1 Chassis and if you have a symptomatic failure I would be glad to help.
garberfc
Posted: Fri Feb 27, 2009 3:29 pm Post subject: |
Hi Jessi,
Thanks for the response.
The TV is about 8 years old and over time the overscan has gotten worse. Also, the brightness is turned up all the way, but the darks are generally closer to blacks.
I figure both those problems can be addressed in the service menu.
Thanks,
Frank |
Posted: Fri Feb 27, 2009 6:07 pm Post subject: |
Usually part(s) drift in value with age. (i.e. Vertical stretches (overscans) or shrinks (underscans) is a very common symptom).
You may be able to temporarily compensate with an adjustment for the drifting part(s), but part(s) usually will continue to drift. |
Posted: Tue Mar 03, 2009 9:19 pm Post subject: |
Hi again frank.
Quote: | Also, the brightness is turned up all the way, but the darks are generally closer to blacks.
This is usually either a crt (picture tube) that is getting weak or you have a chassis problem. Since the G2 is physically on the back of the IHVT you can turn it up. Be carefull as you are dealing with quite high voltage levels and you will not forget it if you get shocked.
On the back of the IHVT there will be two controls. One for focus and the other for G2. If you turn the G2 up to high, the set will go into shutdown. However, turning it up just a little may get you by. The first symptom of the G2 being up too high will be retrace lines going diagonally across the screen. Set the G2 just under this point.
On of the symptoms of a crt getting weak will be a poor gray scale. The best way to check this is to watch a B&W program. If you have cable, the history channel broadcasts a lot of B&W. If there is a tint of color to the screen while watching a B&W program your crt is fading.
As to the overscan, Does the picture "breath" when the brightness is turned up or down??
Like I said before, The service menu is not the way to "fix" your tv. Most people make the problem worse rather than better. (no offence)
