SHARP 27" TV 27n-s300 SHUTDOWN PROBLEM
LEE
PostPosted: Sat May 09, 2009 4:17 pm    Post subject: SHARP 27" TV 27n-s300 SHUTDOWN PROBLEM Reply with quote
Shuts down after 5 to 15 minutes of no problem picture. Must be unplugged for several hours before it will turn on again, then same problem. What should I check for?
PostPosted: Sat May 09, 2009 5:33 pm    Post subject: Reply with quote
check for cracked solder joints on the circuit board. Specifically check around the ones near heat sinks.
If that doesn't locate it, start checking for bad electrolytic capacitors.
