Sharp 32K-S400 Dead
_Tommy
PostPosted: Tue May 12, 2009 3:52 pm    Post subject: Sharp 32K-S400 Dead Reply with quote
This set shuts down and you have to unplug it to try it again. Have checked many caps and diodes to no avail. Any body have any clues? Thanks.
_Tommy
PostPosted: Tue May 12, 2009 3:52 pm    Post subject: Reply with quote
When turned on the HV goes to 30K and then shutdown.
_Tommy
PostPosted: Tue May 12, 2009 3:53 pm    Post subject: Reply with quote
I connected a light bulb to the collector of the hot but it still shut down.
Ideas?
_Tommy
This set is now fixed. It was loose solder connections on the vertical IC
chip causing it to shut down. Thanks everyone.
