thre3kgt
Posted: Thu Mar 17, 2016 4:20 pm Post subject: Sharp Aquos LC-32D64U - HDMI Ports Not Working/Loud Static |
Sharp Aquos LC-32D64U 32" TV I bought 4th quarter of 2008.
TV worked fine in the afternoon, I went out, and we had some lightning in the area that evening. Came back, turned TV on and I just got black screen/no sound. HDMI is hooked from cable box to input on tv, so I tried switching to the second HDMI port, nothing. Additional to this, after about 30 seconds of the TV being on, a crackling static sound starts, slowly gets louder and louder, and after about 30 seconds more it is extremely loud. Changing volume/muting has no affect. Rest of the houses tv's are working fine still so I hooked it up to a different cable box and used different HDMI cable, same result. I've also done the standard unplug everything/reboot cable box type of stuff to to no avail, and TV is plugged into surge protector so not sure if lightning could actually affect it or not.
Finally had some success using RGB cables, as well as a Red and White cable for the sound. Now the picture and sound works, but the static sound issue remains.
TV has always worked perfectly before this.
Thank you so much for any help I'm a noob to this stuff. |
