Sharp Aquos LC-37D44U Power and OPC Blinking
ntehicks
PostPosted: Sun Nov 06, 2011 12:13 pm    Post subject: Sharp Aquos LC-37D44U Power and OPC Blinking Reply with quote
My Sharp 37" TV when I plug it in the power and opc blink together twice and then the opc blinks another 3 times. I have done a few google searches and a few others have had same issue but no one seems to have the answer. I have a service manual it tells me that "DET_POW2 (pin 35): Abnormal (L). Panel power is not applied.
if error is detected during operation, error standby is activated by polling.
I am not sure exactly what this means so I thought I would post it and see if someone could help. thanks.
ntehicks
PostPosted: Thu Nov 10, 2011 12:27 am    Post subject: Toast Dead Panel Reply with quote
after doing some searching on the web. I found a way to test to see if it is the panel by removing the ribbon cables going to the panel. once I did this the tv turned on and I get the back light. dead panel.
