sharp HD tv no picture
daedragoon
PostPosted: Sun Aug 02, 2009 12:01 am    Post subject: sharp HD tv no picture Reply with quote
hi I have a Sharp liquid crystal tv model LC-9SB25U.
the tv turns on, the little green light is on, there's sound and the tv monitor lights up, but there's no actual image on the screen. anyone know how to fix this? or at the very least about how much this might run to get repaired at a tv repair shop?
thanks
PostPosted: Sun Aug 02, 2009 10:15 am    Post subject: Reply with quote
Little search engine (Google) says: "Your search - LC-9SB25U - did not match any documents." Question
PostPosted: Mon Aug 03, 2009 12:01 pm    Post subject: Reply with quote
The correct Model number for this set is, I believe, is LC-19SB25U.
This is a hotel set Confused .. First, can you get the menu to come up when you press the menu key on the remote?
If you can, you are probably in the hotel mode.
