Sharp LC-15AV7U screen lights up for a second
_Tony
PostPosted: Tue Nov 11, 2008 11:46 am    Post subject: Sharp LC-15AV7U screen lights up for a second Reply with quote
Sharp LC-15AV7U screen lights up with no background. Anybody have any luck with this model?
_randy
PostPosted: Tue Nov 11, 2008 11:47 am    Post subject: Reply with quote
Not sure if this is exactly what you are experiencing, but I have had
several of that model that had a backlight issue. one lamp would not light,
so you would see a blue screen for a few seconds, before it would shut
itself off. If this is your problem, examine the screen closely while it is
up, and see if there is a band across it that shows slightly darker. I have
fixed one of these by soldering connections in the inverter circuit. The
others required main board replacement.
Have a great day!
PostPosted: Tue Nov 11, 2008 12:40 pm    Post subject: Reply with quote
Sharp has an issue with many of their sets and the fix is simple for about 50% of them.
Remove the inverter and clean the oxide from the ground points and reinstall the inverter and make sure the screws are tight. Loose screws are causing the problem.
