Sharp Guest
Posted: Sat Jul 21, 2007 1:35 am Post subject: Sharp TV Service Menu Codes |
* Unplug the TV
* Press and hold the {VOL -} & {CH+} buttons.
* While holding the above buttons, plug in the TV.
* The TV will turn on with the Service Menu displayed.
* There are 5 category menus:
Deflection - Signal - Feature - Fix Value - EEPROM
* Use {CH+} {CH -} buttons to select a category.
Note: Not all models will have 5 categories.
Some will jump to 'Signal' category.
* Use {VOL+} to enter the category.
* Use {CH+} {CH -} buttons to select the item to be adjusted.
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu. |
Sharp Guest
Posted: Sat Jul 21, 2007 1:36 am Post subject: Service Menu Access |
LCD TVs :
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
Sharp Guest
Posted: Sat Jul 21, 2007 1:36 am Post subject: Service Menu Code |
PROJECTORS:
* Press {INPUT} {UP} {DOWN} {ENTER} {ENTER} {MENU}
buttons on the back of the Projector.
* Now use the remote control to navigate through menus.
* To exit the Service Menu:
buttons again on the back of the Projector. |
Sharp Guest
Posted: Sat Jul 21, 2007 2:04 am Post subject: Service Menu Key Sequence |
PROJECTOR:
* Press {UP} {UP} {DOWN} {DOWN} {RIGHT} {LEFT} {ENTER}
buttons on the Projector (or remote ?).
* To exit, turn the Projector Off. |
