Sharp XV-Z15000 Projector Service Code
convexion
PostPosted: Fri Apr 23, 2010 7:19 pm    Post subject: Sharp XV-Z15000 Projector Service Code Reply with quote
Hi, I was wondering if anyone might have this code. I tried the two listed in the service code posts for Sharp but neither worked. Thanks!
PostPosted: Sat Apr 24, 2010 12:46 am    Post subject: Reply with quote
Assuming "lamp out" won't go away... Question Try a reset of the lamp: Plug in your ac cord. Hold the enter,and the down arrow and the right arrow all at the same time then press the power on.Question
That was for a similar model. Don't know if helps or not.
convexion
PostPosted: Sat Apr 24, 2010 1:08 pm    Post subject: Reply with quote
No, unfortunately I have a color wheel index problem which is producing a lot of nasty banding. I know it's a simple fix if you can get into the service menu but I just can't find any codes that work.
convexion
PostPosted: Tue Apr 27, 2010 1:13 pm    Post subject: Reply with quote
Ended up fixing the issue by opening the case and toggling the service menu as shown in the service manual. Still, it would be nice to be able to get to the service menu via a code rather than go through all the nonsense of taking it down and popping the case.
