Sony 24FS120 service menu defaults
RyanJTX326
PostPosted: Sat Oct 15, 2011 11:18 am    Post subject: Sony 24FS120 service menu defaults Reply with quote
Hello all. The other day I was messing around in the service menu (which I shouldn't have been doing) trying to fix the image rotation and ended up changing a lot of things. It looks okay, but, I saved the settings, and unfortunately didn't write the default values down. If any of you happen to have the default values it would be appreciated. I only messed with the DEF-menu so I don't need the values for all the menus.
Thanks!
PostPosted: Sat Oct 15, 2011 3:56 pm    Post subject: Reply with quote
RyanJTX326
PostPosted: Sat Oct 15, 2011 4:24 pm    Post subject: Reply with quote
Thanks a ton! Mr. Green
PostPosted: Sat Oct 15, 2011 4:45 pm    Post subject: Reply with quote
There's no guarantee that (initial) value in the chart is the (actual) value you started with.
RyanJTX326
PostPosted: Sat Oct 15, 2011 4:58 pm    Post subject: Reply with quote
Of course. It gives me a good starting point though. More than anything I wanted to make sure that I kept the aspect ratio perfect. Luckily it seems that I did (by those values).
