NickSteel
Posted: Sun Sep 18, 2016 1:09 pm Post subject: |
Try unplugging, cleaning and then reseating the LVDS/Tcon cables. |
NickSteel
Posted: Mon Sep 19, 2016 11:14 am Post subject: Thanks. |
Unplugged/cleaned/plugged the cables. No change, so I will recycle. The things are cheaper to replace than repair these days.
I did replace capacitors in an LG a year ago that fixed that one. If it gets complicated I tend to surrender.  |
Posted: Mon Sep 19, 2016 1:11 pm Post subject: |
IF lines are also over Menus and OSDs is either tcon or panel. |
NickSteel
Posted: Mon Sep 19, 2016 1:46 pm Post subject: Thanks again. |
Lines are as you described, so I consider it "toast". |
NickSteel
Posted: Wed Sep 28, 2016 10:47 am Post subject: |
May try a T-Con board if I find a cheap one. No sense risking more $$ than I have to.  |
