Sony Bravida KDL32S2010 Picture problems
Natalie
PostPosted: Sat May 08, 2010 10:52 am    Post subject: Sony Bravida KDL32S2010 Picture problems Reply with quote
Ihave a Sony KDL32S2010 everything works beautiful, except no picture.
Just changing channels and the picture went out. For the past 6 months have heard on occasion a cracking sound. No red lights flasing on the power saver in the front.
I just replaced the power board and same thing. I can see lights inside with the back cover off, so I doubt if it's the back light board. Anyone have any ideas or had a problem like this. It is only 3 years old. Thanks in advance
PostPosted: Sat May 08, 2010 7:23 pm    Post subject: Reply with quote
As long as the white light you see is inside of the panel (screen) - then you DO have back lights.
Found:
No Picture Has Sound And Backlight Is Lit,
REPLACE TCON BOARD OR PICO FUSE ON TCON BAORD fuse is very small and green and Has a letter P stamped on it next to the connector that hooks to main board. I used a 2 amp pico fuse which worked just fine.
streaks1783
PostPosted: Sun Mar 03, 2013 11:49 am    Post subject: Reply with quote
I have the same exact problem. I found this forum during my research. I replaced the T-con board, but it still is not working. The backlight is working and there is sound, but there is no video at all, including volume, menu, or anything. Any other suggestions?
