Sony KDF-55E2000 DLP 3 blinking red lights
kristopherk
PostPosted: Thu May 20, 2010 5:29 pm    Post subject: Sony KDF-55E2000 DLP 3 blinking red lights Reply with quote
hello, i have a Sony dlp model kdf-55e2000 dlp that recently turned off and starting flashing three red lights followed by a pause and then repeating this over and over. I've done some research and found that the flashing lights mean that the sensor that detects if the door to the bulb is open or not is reporting that it is open. does this sensor ONLY report that the door isn't properly closed or does it also report if the bulb isn't seated properly? I've tried to fix the door and cannot get it to work. please help.
kristopherk
PostPosted: Thu May 20, 2010 5:52 pm    Post subject: Reply with quote
update: i took the cover off the back of the tv so i could get a better look at the switch for the bulb door. looks like its operating correctly. it has two wired that come off of it and into the circuitry. could i connect these two wires together to see if its a defective switch?
ambercothran
PostPosted: Tue Sep 28, 2010 9:29 am    Post subject: I have the same problem Reply with quote
did you find out what was wrong?
