keith
Posted: Thu Jan 01, 2009 2:04 pm Post subject: Sony KDF-55WF655 |
Wanting to diy a problem. After turning it on, about a minute later it begins a rhythmic series of turning off and on. When it's rotated to it's "off" portion of it's cycle, the power/standby light is flashing green. When it returns to the "on" portion of it's cycle the light is steadily green. Is this simple or not?
Thanks |
Posted: Fri Jan 02, 2009 1:02 pm Post subject: |
Do This:
With the set off and cold:
Using your Owners Manual:
Remove the lamp and using a vacuum cleaner, vacuum the screens on the edge of the lamp housing. DO NOT TOUCH THE GLASS PORTION OF THE LAMP WITH YOUR FINGERS.
If the screens are plugged the set will turn itself on and off. If the screens are not plugged the lamp is most likely defective.
keith
Posted: Sat Jan 03, 2009 3:31 pm Post subject: |
Thanks Jesse,
I started out not thinking of the lamp because sound and picture went out together. I pulled the lamp. You mentioned screen(s) (plural ?). I cleaned one screen on top of the lamp. Sometimes being too careful I can be a little tunnel-visioned. After reassembly, the cycle was there again, but changed. Instead of 30/30 on/off cycle it is now 90/30 on/off cycles. Improvement tells me it's the lamp. I'm not going back in to recheck for any missed screens on the lamp right now. At the moment, I'm taking advantage of this "spring-like" weather we're having here in Texas to replace the transmission in my truck.... Too many diy projects?
Thanks,
Keith |
Posted: Sat Jan 03, 2009 4:28 pm Post subject: |
There are two screens that allow the supply air flow thru the lamp. Look at the opposite extreem edge and there will be a second screen
Posted: Sat Jan 03, 2009 4:30 pm Post subject: |
By the way, It is -40 BELOW ZERO here today.
keith
Posted: Sun Jan 04, 2009 12:23 pm Post subject: |
Later in the afternoon/early evening, I took it out again and found what you were talking about. That screen was clean. The other one wasn't that dirty, but it must have been enough. When I reinstalled it the tv worked the rest of the night. Is this some sort of indication that the lamp doesn't have much life left in it? Or would this be just normal, but unmentioned, maintenance?
Thanks, Jesse
Keith
Oh, by the way. Saturday's highs were in the 70's. Monday is supposed to in the 30's. On the balmy side compared with what your seeing. |
Posted: Mon Jan 05, 2009 12:43 pm Post subject: |
Many times when you reach the point of dirty screens you are close to the "end of life" for the lamp.
