sony KDF-E42A10 lcd tv
_Larry
PostPosted: Sun May 03, 2009 6:21 am    Post subject: sony KDF-E42A10 lcd tv Reply with quote
KDF-E42A10 has led flashing 4 times. means the fan for lamp is not working properly. replaced fan lasted 1 week, replaced again about 1 week. fan will still run. the fan detection circuit must be bad.
anyone else have this problem
_Rick
PostPosted: Sun May 03, 2009 6:21 am    Post subject: Reply with quote
More then one fan inside that set...
there are at least 3 fans.....the Squirrel cage fan
sits above the lamp and ballast is the likely
culprit....did you replace the square upright
fan or cage fan?....
the A10 Sony lcd series...is a tough
engine....to get into..with q block right in the way..
good luck....
_Larry
PostPosted: Sun May 03, 2009 6:22 am    Post subject: Reply with quote
i replaced the lamp fan motor. square upright. The odd thing is when I
replaced fan set works immediately, then after a week here we go again. i
pull the optics and check for dust in the small fan.
thanks
