SONY KDL-32S3000 no video
real916
PostPosted: Sun Mar 08, 2009 3:25 pm    Post subject: SONY KDL-32S3000 no video Reply with quote
WHEN I TURN TV ON RED LIGHT FLASHES 6 TIMES THEN IT CUTS OFF THE PICTURE DOES NOT COME ON DOES ANY ONE HAVE A ANSWER THANK YOU
PostPosted: Mon Mar 09, 2009 11:43 am    Post subject: Reply with quote
There is no such model number. I am assuming that the number 5 is actually an "S" and that does compute.
6 Flashes indicates a bad backlight or inverter. It also could mean a loose connection or bad power supply.
The inverters (this unit has 2) MUST BE REMOVED CORRECTLY. if you decide to replace one or both after your determination.
Failure to CORRECTLY remove the inverters will result in a broken lamp or failed lcd screen. This would be a Major, Major, Major problem.
Hope this helps.
PostPosted: Mon Mar 09, 2009 6:54 pm    Post subject: Reply with quote
Note: I only respond with possible answers on this forum. Not private Messages.
Reason: All viewers gain from the questions and answers. Nothing is gained as a forum through private messages.
Sorry
