Sony KDL-40EX710 - Lightning strike and power surge
devilfrmheaven
PostPosted: Sun Jun 11, 2017 11:32 am    Post subject: Sony KDL-40EX710 - Lightning strike and power surge Reply with quote
Hi All,
Im a novice, I am an electronics hobbyist. I recently received a TV that was struck by lightning. Model: KDL-40EX710
TV was sent to Sony for repairs but they trashed it as it was an obsolete model.
I am trying to reverse engineer the power supply board. I have taken the board of the TV and working on it.
The relay latches when I put a 1K jumper on STBY3.3V to POWER_ON. All other 12V does power up for a second and goes dead. I took a reading of input for Optos.
PH6300 - PIN 1 and 2 = 1.09V - Turned on
PH6302 - PIN 1 and 2 = 1.05V - Turned on
PH6100 - PIN 1 and 2 = 8.7V - Blown out?
PH6201 - PIN 1 and 2 =0.96 V - Turned on
I got the circuit for the PSU from the link below.
ftp://helpedia.com/pub/temp/datasheets/monitors/Sony/Sony_1-474-218-11_[SCH].pdf
I am trying to fix the TV myself
Thanks for the help in Advance.
PostPosted: Sun Jun 11, 2017 1:18 pm    Post subject: Reply with quote
What does the POWER_ON pin do when power button is pressed with the set all together?
devilfrmheaven
PostPosted: Sun Jun 11, 2017 2:13 pm    Post subject: Thanks for the quick response Reply with quote
Nothing much, I hear the relay click on, POWER_ON = 3.3V the red LED lights up and then clicks off after 2 or 3 seconds, Red LED goes off.
If I power up and press the Power Button while I have the red LED lit up, POWER_ON = 3.3V then Green LED lights up, POWER_ON = 3.3V and then wait for 1 or 2 seconds. Then Green LED goes off and RED LED lights up and then RED LED goes off POWER_ON = 0V .
Thanks!!
PostPosted: Sun Jun 11, 2017 2:40 pm    Post subject: Reply with quote
With lightning either BAL or Power (or both) may be defective.
devilfrmheaven
PostPosted: Sun Jun 11, 2017 2:57 pm    Post subject: Reply with quote
I suppose both are damaged. Need to get the PSU working so that I can check. I had seen one of the protection ic burnt in an HDMI port
Thanks
PostPosted: Sun Jun 11, 2017 3:04 pm    Post subject: Reply with quote
If HDMI on BAL board is burnt, you may also want to also check whatever was connected to it.
devilfrmheaven
PostPosted: Sun Jun 11, 2017 9:25 pm    Post subject: Reply with quote
Yea the device connected to hdmi is dead now.
devilfrmheaven
PostPosted: Mon Jun 12, 2017 8:38 am    Post subject: Reply with quote
Hello, are there any suggestions for me as to why PH6100 Pin 1 and 2 measure 8 Volts?
