Sony kdl-42w654a - ribbon cable prob
jamescortel
PostPosted: Thu Jan 26, 2017 8:26 pm    Post subject: Sony kdl-42w654a - ribbon cable prob Reply with quote
Hello guys i need some help with my sony bravia tv kdl 42w654a the display is showing some red vertical line, when i open up the tv back cover i noticed the ribbon cable connecting to tcon board is sparking i posted a link video below, is there a way to fix this issue?..thanks
https://youtu.be/wqkiueqxuoI
PostPosted: Thu Jan 26, 2017 8:40 pm    Post subject: Reply with quote
1) Replace the panel or
2) Repair the tab by using a professional tab attaching MACHINE (or send to a panel repair business) or
3) Find some way to make the contacts that are arcing make a tighter connection (piece of non-flammable foam?)
PostPosted: Fri Jan 27, 2017 8:48 am    Post subject: Reply with quote
Thanks for posting a video. i'm having a hard time interpreting some of it.
Is that ribbon connector sparkling like a fuse? or is that the light from the panel behind it.
Are you fixing microwave popcorn, or is the TV making that sound?
