sony kdl-46v4100 has audio no video
Wendell2014
PostPosted: Thu Sep 25, 2014 8:08 am    Post subject: sony kdl-46v4100 has audio no video Reply with quote
customer dropped the set off stating that the picture would drop out alot before failing completely, i know these models are known for having crappy lcd panels and high failure rate for the t-con boards.
I had replaced the bad t-con board on this unit and replaced the fuse it blew on the mainboard, tv still has audio but no video just see the backlight.
curtis wolfe
PostPosted: Thu Sep 25, 2014 12:52 pm    Post subject: Reply with quote
DISCONNECT EACH CABLE TO THE PANEL DRIVE BOARDS ONE AT A TIME. IF YOU GET HALF A PICTURE THEN IT'S THE PANEL.
Wendell2014
PostPosted: Fri Sep 26, 2014 6:36 am    Post subject: Reply with quote
tried that no change, i noticed a very small green flashing led near the video processor on the mainboard i dont think its indicating an error but i am not sure
