Sony KDL-48W600B - sound, no picture, has backlight   Goto page 1, 2  Next
rbudrick
PostPosted: Fri Mar 23, 2018 9:29 pm    Post subject: Sony KDL-48W600B - sound, no picture, has backlight Reply with quote
Hi Folks,
As per the title, this TV just stopped showing anything onscreen, including menus. It's a black screen, but the backlight is on. Many sites have people complaining of the same issue, and they all recommend almost the same non-working solutions:
1. Unplug the TV for a few minutes. Hold the power button for up to 30 seconds to discharge. Neither work, even leaving it unplugged for days.
2. Replace the TCon board.
The problem is there is no Tcon in this set. There's a power board, a tuner board and a main board. I have replaced all three without change. There also appears to be two inverter boards (I'm assuming...they are long and skinny and joined by a flat ribbon cable), but since I have backlight, I ruled them out.
This happened last year and after taking the set apart with no obvious fix, I put it back together and it just started working again. It'd been fine since, except the issue started up again and now won't resolve.
I'm totally stumped on this,, Hope you can help! Could the LCD Panel itself have failed? Where would I even buy that? I see nothing on eBay.
Thanks Very much!v
Yours,
Rob
PostPosted: Fri Mar 23, 2018 11:44 pm    Post subject: Reply with quote
Tcon should be at other end of Flat Flexible Cable (FFC). Part of Panel.
Code:
https://encompass.com/item/10191852/Sony/A-1989-963-A/P-mod(ns4s480dnd0101)
rbudrick
PostPosted: Mon Mar 26, 2018 2:50 pm    Post subject: Reply with quote
OK, I see. Thanks for the reply and sorry for delay in getting back.
I thought the board you referenced was an inverter board because it was so long and thin, as inverters usually are (flat ribbon connects to one long skinny board, and that one connects to another board by another short ribbon. Both attach directly to the LCD. Is this really the TCON? If it is, there are no inverter boards in this set...are there sets now without those? ). The double-board, for lack of a better term, does not appear to be user-replaceable, as it connects to the LCD via those ribbon cables that are not user-serviceable. Pics:
https://www.dropbox.com/s/p9jk3ombpipoeiq/20180325_145430.jpg?dl=0
https://www.dropbox.com/s/vn77lvlc8xpiun9/20180325_145335.jpg?dl=0
https://www.dropbox.com/s/j0fsmna8eptnd7h/20180325_145311.jpg?dl=0
https://www.dropbox.com/s/2few2emac4391ek/20180325_145255.jpg?dl=0
https://www.dropbox.com/s/9zv6w52pdjbjgyq/20180325_145243.jpg?dl=0
https://www.dropbox.com/s/i0eo5dums4iekzl/20180325_145023.jpg?dl=0
https://www.dropbox.com/s/nwt96tea6pkv9d8/20180325_145357.jpg?dl=0
https://www.dropbox.com/s/pqm2lapk4xt4hot/20180325_145216.jpg?dl=0
https://www.dropbox.com/s/ldqdufs96zmm7kp/20180325_145157.jpg?dl=0
EDIT: Sorry, I tried to get these to show as images, but they don't work when adding the img tags.
Edit 2. Googling the model numbers seem to indicate this is known as a matrix board and not the TLG. So, does my set have no TLG and no inverter boards?
Thanks again!
PostPosted: Mon Mar 26, 2018 3:34 pm    Post subject: Reply with quote
Backlight Type: LED
NO inverter boards.
Yes that is the tcon (only replaceable by replacing the whole panel).
You could see if the surface-mount fuse to the right of where ribbon connects in last picture is good and has 12 volts on both sides of it.
rbudrick
PostPosted: Mon Mar 26, 2018 4:53 pm    Post subject: Reply with quote
OK, thanks! Would a simple continuity test tell me the same, being a fuse and all? Just trying to avoid a shortage if doing it while powered.
Thanks again!
-Rob
PostPosted: Mon Mar 26, 2018 5:15 pm    Post subject: Reply with quote
Say the fuse is good, How do you know if 12 volts is reaching the Tcon?
rbudrick
PostPosted: Mon Mar 26, 2018 5:22 pm    Post subject: Reply with quote
Fair point. Unlike everything else in the set which is easily accessible, this pcb is seriously awkward, as the stand needs to be removed along with all the other PCBs to get at it, which also means I'd have to macguyver a way to reconnect them all temporarily after removing them. My workspace is rather small and is the only semi-convenient place in the house to work on it. Possible, but risky and awkward.
Thanks again!
rbudrick
PostPosted: Mon Mar 26, 2018 5:47 pm    Post subject: Reply with quote
Well, there's some news, on double checking. The fuse was visible and easily accessible to the probes of my multimeter, as there was a gap in the shielding next to the ribbon. The fuse has continuity, but when I set the meter to the up-to 20 volts direct setting, the negative probe to ground (at the power port), and the positive probe to either side of the fuse, I get absolutely nothing, even though the ribbon has continuity on every pin from the main board to the TCON. I assume the ribbon is where power comes into the TCON, because besides the ribbons that lead to the lcd, there's no other cables to supply it that I see.
Any ideas? Or am I pretty much out of luck?
Thanks again!
rbudrick
PostPosted: Mon Mar 26, 2018 6:23 pm    Post subject: Reply with quote
OK, I made a dumb rookie move. The TV was only on standby when I tested the fuse. I powered the TV to on and the fuse does indeed get +12.
PostPosted: Mon Mar 26, 2018 7:48 pm    Post subject: Reply with quote
https://imgur.com/nD40oNJ
Goto page 1, 2  Next
Page 1 of 2
